Audio/Video Gear and Systems
(Moderators:
JohnR
Blackmore
welcome
welcome
0 Members and 1 Guest are viewing this topic. Read 2832 times.
carloll
Newbie
welcome
28 Oct 2018, 09:08 pm »
thanks for the add.
I am a DIYer and as a final project of my career I would like to find out the sound of the open baffle
I'm here because I want to build a dipole system with sub h-frame, so I need to learn as much as possible.
Thank you all
Facilitator
Audio Transformers Consulting
Re: welcome
28 Oct 2018, 09:10 pm »
Welcome aboard Carl
By Sub do you mean under 300Hz in a two-way speaker?
Don't Panic / Mostly Harmless
Re: welcome
Reply #2 on:
29 Oct 2018, 07:22 am »
Greetings & Welcome to AC carloll
Phil A
Re: welcome
Reply #3 on:
29 Oct 2018, 12:30 pm »
Welcome!
carloll
Newbie
Re: welcome H-FRAME
Reply #4 on:
31 Oct 2018, 12:50 pm »
sorry I'm new to the forum and I did not see the messages.
Based on the studies of Mr. MJK I would build an H frame DSP cutted at 100Hz controlled by a QSC amplifier
The upper range in OB is managed by a passive 12 lta eminence plus a tweeter
Listening room is an attic of 8m x 3.60 with a low roof
I'm not sure to use a pair of 15 "woofer or a single 18” woofer
you have got any suggestions? Thanks
Facilitator
Re: welcome
Reply #5 on:
31 Oct 2018, 03:21 pm »
My personal taste is two 15'' if you can find 16 ohms drivers to connect them in parallel to +3dB.
(Moderators:
JohnR
Blackmore
welcome
