0 Members and 1 Guest are viewing this topic. Read 2214 times.
What stands are people using for Mini T speakers? And what height are the stands? Any Pangea and Target comparisons would be appreciated. Thanks.
Hi bobfWe have a custom Target stand that has the same size top as the bottom of the Mini T and can be bolted to the stand if you remove the feet on the bottom of the Mini T.james
Through my Bryston dealer I ordered the Target MR50 20" stands. Is this the right one to bolt the Mini T to the top plate?
Hi BobYes but you must order the custom tops as a separate order if you want.Standard Top See below
