DEMO Ming-Da Upgraded MC34-B w/Svetlana 6L6 tubes
0 Members and 1 Guest are viewing this topic. Read 1798 times.
Bill Baker
    • Musica Bella Audio
« on: 18 Jan 2005, 02:44 am »
This amplifier comes with coupling capacitors upgraded to SoniCap units (x6 pieces), Dale/Vishy Emitter/Cushion resistors, carbon volume control and a new quad of Svetlana 6L6 tubes. Also included is the tube cage. A beautiful, seductive presentation at a very real world price. This is the last of our available Ming-Da amplifiers. This amplifier has been tested and biased. Approximately 15-20 hours of use.
Asking $695 + $20 shipping.
Bill Baker
Specifications
« Reply #1 on: 18 Jan 2005, 02:50 am »
Sorry, here are the specifications.
Details
*power short circuit protection
*headphone output jack on the front panel
*protective plexi-glass tube cover, beautiful, convenient
*detachable power cord
Specifications
*output power 22W x2, 8 ohms, 1khz: Class AB
*output impedance 4Ω 8Ω
*input sensitivity 200mv
*input impedance 100K
*total harmonic distortion ≤0.8%
*signal-to noise ratio 86dB
*input jacks: CD, AUX
*output impedance: 4 Ohm   8 Ohm
*frequency response: 20Hz-40KHz   ±1dB
*tubes:  6N3P (6L6/KT66) x4,  6N1-J x2, 6N2 x2
*supply voltage AC117V/220V 60Hz/50Hz
*power consumption 135W
*volume 12-1/2" L  x  11-1/2" D  x  8-3/4" H
*weight 31 Lbs. (gross weight 38 Lbs.)
*Headphone Jack: on Front Panel, regular 1/4" din size
*Headphone/Speaker selector switch: on Left side.
Bill Baker
« Reply #2 on: 24 Jan 2005, 08:48 pm »
Well, the MC34B is gone for a while. It has been sent to a speaker ditributor to evaluate a pair of horns.
 I will re-post it when/if it comes back.
