Firefox Config mistake
0 Members and 1 Guest are viewing this topic. Read 2282 times.
« on: 21 Oct 2018, 05:15 am »
I made a mistake :duh: deleted the extension.ui.locale command line in the FF 62 about:config file.
How I include a new line to type this command?
There is no New option on the right click mouse.
WGH
Re: Firefox Config mistake
« Reply #1 on: 21 Oct 2018, 05:47 am »
Download a fresh copy of 62.0.3 and re-install.
srb
« Reply #2 on: 21 Oct 2018, 05:49 am »
There is no delete function in the about:config webpage, so if you somehow deleted a preference line item, did you directly edit the prefs.js file?
You can create a new entry on the about:config webpage by right-clicking in the preferences window and
1. select  New > Boolean
2. enter the preference name extensions.ui.locale.hidden
3. select the Boolean value  True  or  False
If you're directly editing the prefs.js file the line to add (if missing) is
user_pref("extensions.ui.locale.hidden", true);
« Last Edit: 21 Oct 2018, 07:01 am by srb »
« Reply #3 on: 21 Oct 2018, 05:59 am »
OK, just fix it. It need type the command in the comand line first and after click new.
Thanks guys :thumb:
Big Red Machine
« Reply #4 on: 21 Oct 2018, 11:46 am »
Thank goodness it's fixed because I had no bleeping idea what you guys were talking about :duh:
WGH
« Reply #5 on: 21 Oct 2018, 03:14 pm »
I knew there was an easier fix than just re-installing but it was late. Steve always has the right answer  :green:
« Reply #6 on: 21 Oct 2018, 06:58 pm »
I was trying to change the FF language, in the v62 Mozilla modify it to the local language, no success yet.
Lasts try was:
menu/options
and
extensions.ui.locale.requested
and
extensions.ui.locale.requested=en at prefs.js
Any idea? Mozilla help is useless.
srb
« Reply #7 on: 21 Oct 2018, 08:40 pm »
To enable a language in Firefox prefs.js, you must first download and install the relevant language pack.
Is this the procedure you're following?
https://support.mozilla.org/en-US/kb/use-firefox-interface-other-languages-language-pack#w_how-to-manage-language-packs
« Reply #8 on: 21 Oct 2018, 09:18 pm »
Yes this is it. I even removed the other languages I had to force it assume english but it dont work, FF v62 always assume the ip location or W10 location info.
