Toronto AudioFest 2018
0 Members and 1 Guest are viewing this topic. Read 10240 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 16 Oct 2018, 06:19 pm »
Hi Folks,
Setting up tomorrow for the Toronto AudioFest - will post pics and comments as we go.
james
undertowogt1
Re: Toronto AudioFest 2018
« Reply #1 on: 16 Oct 2018, 07:02 pm »
I did not know about this show. I looked it up and it is free tickets when you register to attend. I register just in case I have time to stop by.
FireGuy
« Reply #2 on: 16 Oct 2018, 07:29 pm »
Darn, I'll be in New Jersey.  Too bad, wanted to go to this one.  All other shows are just too far away and their dates never seem to sync up with my travels.
« Reply #3 on: 18 Oct 2018, 12:10 am »
Preliminary setup
james
mrhyfy
« Reply #4 on: 18 Oct 2018, 01:36 am »
what-the :o
wall-o-sound
« Reply #5 on: 18 Oct 2018, 06:48 am »
HI mrhyfy,
Yes I am calling it the T-Rex !
The top section is custom as it has a special pad on the bottom and a special connection arrangement on the back.
Sort of a super D’Appolito array.
james
MarvinTheMartian
« Reply #6 on: 18 Oct 2018, 09:41 am »
How retro … ala stacked Advents  from the 70's  : )
James, did you have to tweak the crossover?
Shawn
« Reply #7 on: 18 Oct 2018, 09:47 am »
Shawn
Hi Shawn
No the advantage of the Bryston BAX-1 Active Electronic Crossover for the Model T is such that I did not have to change any settings for the stacked system.
james
veloceleste
« Reply #8 on: 18 Oct 2018, 10:14 am »
HI mrhyfy,
james
Wow, impressive!!!!! Since I'm losing my filters I'll be the one to ask: Does this have anything to do with legalization? :D
Stu Pitt
« Reply #9 on: 18 Oct 2018, 10:25 am »
I see a good inch or two of additional clearance before you hit the ceiling. Surely you could’ve utilized that, James. A super tweeter, perhaps? Why stop there?  :lol:
« Reply #10 on: 18 Oct 2018, 11:21 am »
Hi Stu
Yes it starts to approximate a line source when you get close to the floor/ceiling distance.
james
Pundamilia
« Reply #11 on: 18 Oct 2018, 02:39 pm »
@Marvin the Martian
Ah, stacked or double Advents! I wonder what my old system would sound like if I could compare it to what I have today.
Too bad, there isn't some sort of "time machine" that would allow us to compare the various iterations of our systems as they evolved over time. Hopefully, the improvements in technology and our audio budgets result in a vastly superior sound!  :D :D
HsvHeelFan
« Reply #12 on: 18 Oct 2018, 06:35 pm »
Mr. Tanner,  what's the rest of the system components?  Are you still using the 3 channel Bryston amps and one for each stack?
HsvHeelFan
veloceleste
« Reply #13 on: 18 Oct 2018, 07:12 pm »
Hi James,
Is Bryston going to show at the Capital Audio Fest? If so, will this be the system?
Thanks.
« Reply #14 on: 18 Oct 2018, 11:10 pm »
Hi James
Stopped in today for a quick listen during setup - SUPERB SIR. :thumb:
MJ
« Reply #15 on: 19 Oct 2018, 06:55 am »
HsvHeelFan
Hi Hsv
System consists of:
Bryston BDP-3 Digital Player/Streamer
BDA-3 DAC
BP26/MPS2 Preamplifier
BAX-1 Digital Crossover
Two 21B three-channel amplifiers
Bryston 20 Amp BIT Isolation Transformer
Target Component Stands
Bryston Cables
And of course the new Bryston T-Rex Active Speaker System.
james
« Reply #16 on: 19 Oct 2018, 06:57 am »
Hi James,
Thanks.
Hi velo
No sorry we will not be there.
james
« Reply #17 on: 19 Oct 2018, 07:06 am »
@Marvin the Martian
Hi Pundamilla
Ah yes - you take me back - I also owned the stacked Advents  :thumb:
We did not know it then but there are a lot of advantages to this kind of speaker array.
1. First you are moving a lot of air at very low distortion which results in real world dynamics.
2. Because you have woofers at both the top and bottom of the speaker array you are loading the bass frequencies into the room at 4 different pressure points.  This really works well at smoothing the bass response throughout the listening room.
3. With a multi-driver array like this the ability to fill the room with sound is effortless and you can walk very close to the speaker or move far away and you will notice very little difference in sound pressure level.
4. Folks the speakers literally disappear and you just have this huge wall of sound (with good imaging and depth) in front of you.
james
« Last Edit: 19 Oct 2018, 12:08 pm by James Tanner »
« Reply #18 on: 19 Oct 2018, 07:51 am »
TJ-Sully
« Reply #19 on: 19 Oct 2018, 11:21 pm »
Sick setup!! Nice work Bryston crew!  :thumb:
