Vandersteen VCC-1 Center Channel Speaker $275
0 Members and 1 Guest are viewing this topic. Read 903 times.
Hear Clifford Brown
« on: 10 Oct 2018, 01:21 pm »
This is a high-end audiophile grade loudspeaker, designed for home theater that performs very well.  I have one in my main system.  The one for sale was in a second system and no longer needed.
End caps and fabric are in excellent condition, no snags, tears or holes in the fabric.  The wood finish like new except for one “scratch” on the top that could probably be rubbed out.  It’s not deep at all, can’t be felt and is barely visible.  Used in a dedicated audio room, with no exposure to tobacco, dogs or cats.
Shipping in original box is extra at actual cost, no charge for PayPal.
From Vandersteen:
The VCC-1 is the only center speaker that incorporates integral design solutions to the specific center channel requirements. It is immune to lobing response variations and performs consistently at any height or positioning. It is magnetically shielded and can be compensated for any environment. It maintains the critical phase integrity of the original sound and fully complements the main speakers.
The VCC-1's coaxial driver is a combination of a 6½ inch woofer and a 1 inch dome tweeter that share the same acoustical center and radiate as a single point source. The aligned driver is immune from multi-driver interference and the resulting response variations and phase irregularities that plague conventional center speakers. The VCC-1 maintains consistent sonic performance over an expansive listening area without hot spots, drop outs or timbre aberrations.
VCC-1 Specifications
Coaxial Woofer/Tweeter
6.5" Mineral-Filled Polycone with Die-Cast Basket with 1" Critically-Damped Alloy-Dome Tweeter
Recommended Amplification 30-200 Watts Into 8 Ohms
Frequency Response 80Hz -- 21kHz +/- 3dB
Sensitivity 86 dB, 1 meter with 2.83 volt input
Impedance 8 ohms nominal 5 ohms
Crossovers First order/6dB per octave, 3.5kHz
Input Terminals Barrier strips, 7/16" max width
Dimensions (WHD) 12 1/8" x 9 1/4" x 10 1/8"
Weight 23 lbs.
