SOLD: Daedalus Athena V2
0 Members and 1 Guest are viewing this topic. Read 1453 times.
easystreet
« on: 29 Sep 2018, 05:38 pm »
It’s been almost seven years since I drove to Ferndale, Washington and picked up this pair of Daedalus Athena speakers at Lou Hinckley’s workshop. Since setting up Lou’s beautiful speakers in my living room, I’ve changed literally every other component in my system, and the Athenas have always let me hear the smallest nuances in these changes. I am asking $5500 plus shipping.
So what do you get with these speakers, besides a gorgeous hardwood cabinet – American walnut in my case – that will look beautiful in any room?
You get a speaker that is exquisitely balanced, with a seamless, organic presentation. Tone is natural and dense. There is an immediacy to the presentation that brings musicians “into the room,” partly because these speakers are very efficient – 95 decibels – and easy to drive with their steady 6 to 7 ohm load. Almost any amplifier will drive them. I first used a Shindo Monbrison/Cortese combination, which puts out 10 glorious watts of singled ended tube tone, and was never wanting for power. Most recently, I’ve been using a Crayon CFA 1.2 integrated solid state amp (63 watts into 8 ohms), and the Athenas have transparently displayed the high resolution and huge, light-filled soundstage of this amp. I’ve also heard these same speakers with low-wattage solid state (First Watt) and high-wattage solid state (Modwright) and they take everything in stride, revealing the personality of whatever amp you choose as a partner.
You also get a speaker that fills a room with a large, live sound, in part because they do the power zone (100hz to 400hz) so well. This mid to upper bass range is presented very evenly and robustly. You also get excellent tight, low bass response. In my living room, which leaks quite a bit of bass with lots of windows and openings to other rooms, I measured solid bass down to 32hz (down just a few decibels) and usable output at 25hz. The speakers do this despite a modest height and footprint. The aperiodic port increases efficiency and makes the speaker sound more like a sealed enclosure. The Athenas are also easy to set up and place, though they will reward careful setup with excellent imaging and tonal balance.
This pair of Athenas have been upgraded with almost all of Lou’s various improvements over the years. Thus, they include the v.2 all-poly crossover, new bass drivers, trim rings, and associated crossover changes, and upgraded wiring. Also included in your purchase will be Soundocity outriggers, which are beautifully built and ensure a stable foundation. The outriggers also allow for micro-adjustments to your listening position and work well on uneven floors, if that is an issue.
The speakers are in perfect working condition and there are no dings or scratches to the beautiful finish. I rate these as a solid 8/10, primarily because the walnut finish is slightly lighter in one speaker, mostly on one side that was facing a window. That should go unnoticed in most rooms and from most vantage points. As the photographs demonstrate, you will be hard pressed to see this.
These can be picked up in Seattle or I can ship with the original shipping boxes. I have been the only owner of these speakers.
« Last Edit: 8 Oct 2018, 07:04 pm by easystreet »
jonbee
Re: FS: Daedalus Athena V2
« Reply #1 on: 5 Oct 2018, 10:04 pm »
I heard these Athenas right after Easy got them, and I was totally knocked out by them. Gorgeous craftsmanship and sound to match. I was very surprised to hear a speaker with such conventional looking drivers offer the high resolution and lack of coloration normally associated with high-tech materials, but with more body and image density.
As a result I bought my own pair of Daedalus speakers in short order and loved them. The v2 upgrade, which these have, makes a huge difference across the board.
These are pure magic, and like all Daedalus v2 speakers they somehow do all the high end audiophile things right while also sounding more like live music than most high end speakers at any price.
The Athenas are also very room and wife friendly, fitting perfectly in rooms from pretty small to pretty large.
The pics do not do justice to these beautiful instruments. These have the rare optional maple inserts on the front.
I'd be perfectly happy with these in my own main system forever, but my wife has married my $$$$ Avalons (bigamy?), and I want to keep both of them. If not for that these would be in my living room right now.
I've heard them a number of times, and always considered it a treat. Someone is going to get lucky!
« Last Edit: 6 Oct 2018, 03:29 pm by jonbee »
easystreet
« Reply #2 on: 8 Oct 2018, 07:03 pm »
SOLD!
