VPI Cartridge Recommendation
0 Members and 1 Guest are viewing this topic. Read 4035 times.
Don_S
« on: 28 Sep 2018, 07:52 pm »
Considering a VPI Prime. Dealer recommends Ortofon 2M Red vs Blue or Bronze.  Any experience with these cartridges?  Especially appreciated if the experience is on a VPI TT.
twitch54
Re: VPI Cartridge Recommendation
« Reply #1 on: 28 Sep 2018, 09:10 pm »
No experience with either of those but a long time VPI guy here (Aries III) and a long time Benz Micro guy as well
RezIndie
« Reply #2 on: 28 Sep 2018, 10:43 pm »
You have to try the Hana SL - it is UNREAL. It blows away carts at 2x the cost.
rotarius
« Reply #3 on: 29 Sep 2018, 01:04 pm »
I can tell you from experience, the Ortofon Quintets are a big step up from the 2M series.  The Quintet red is better than the 2m blue and Quintet blue is better than the 2M bronze.  Don't know about the Black though.  Are you looking at high output carts only?
Escott1377
« Reply #4 on: 29 Sep 2018, 03:33 pm »
I have a Soundsmith Voice on a VPI Classic.  I remember seeing where VPI recommends Peter's cartridges w/ their tables.
Don_S
« Reply #5 on: 29 Sep 2018, 04:19 pm »
Phono stage is MM or high-output MC.  I think it is safer to stick with MM (e.g. Ortofon 2M vs Quintet).
Nick77
« Reply #6 on: 29 Sep 2018, 07:36 pm »
+1     :thumb:
johnto
« Reply #7 on: 29 Sep 2018, 09:55 pm »
VPI Aries Scout owner here currently using Soundsmith Carmen II fantastic sound. I did have to add more weight to the headshell but it's available on eBay for about $5.00. Also used a Sumike Bluepoint Evo 3 with great results.
who?me?
« Reply #8 on: 29 Sep 2018, 10:38 pm »
I have a VPI Scoutmaster II, and I first started out with a 2M Black,
then moved up to the ladder to a Quintet Black, which is excellent.
Since the Prime is a $4000 turntable,
it will reward you most with a comparable quality of cartridge, such as MC.
You mean the Prime, right?? Not the Scout??
No one in their right audiophile mind would put a
MM 2M Red cartridge on a $4000 TT.
Don_S
« Reply #9 on: 29 Sep 2018, 11:35 pm »
Yes, Prime.
BobM
« Reply #10 on: 29 Sep 2018, 11:38 pm »
The cartridge and phono stage have to be compatible. If you have a $500 phono stage that only accepts moving magnet type output, then there's where you have to look. So a $500 phono stage means a $500 cartridge, for the most part. If your phono can deal with low output moving coils, or if you are willing to get a transformer or head amp, then that's a better option, but also more expensive.
Basically, it's a budget thing. Get the best you can afford, because the more $ you throw at analogue the better it gets.
