Omega Loudspeakers Super Alnico Monitor High Output SAM HO & Stands (price drop)
0 Members and 1 Guest are viewing this topic. Read 3042 times.
peckjed
Mint condition Omega Super Alnico Monitor High Output speaker. The speakers in the photos are in mint condition and sound awesome. The dimmensions are slightly different from the website at 24" H x 12" W x 14" D. Just a bit wider than the website! These come with the A&E stands that are pretty much identical to the Sound Anchor stands.
I have the shipping boxes for everything, but would love a local purchase (Connecticut)!
$30002500 or would consider trades around Audio Note AN-E type speakers.
THE NEW OMEGA FLAGSHIP MONITOR, the Super Alnico High Output Monitor with OMEGA SYNERGY DRIVE.
Shown above in Level 2 Ebony on Skylan Stands
The Super Alnico High Output Monitor builds on the mesmerizing performance of the cult object Super Alnico Monitor taking the legendary Omega sound to the next level.
The Super Alnico High Output Monitor is not a 2 way design, but a 1.5 way design.
What separates it from a 2 way design?
The drivers are identical except for the dustcap of the low frequency (LF) driver.
There is no power sucking, midrange muddying crossover.
The LF driver is cut off at 200Hz, so there is no phase and time misalignment as in a two way speaker.
The HF driver still functions as a single driver, single point source running full range.
2 drivers work less hard as 1 driver.
Same combined surface area as a 9.5" single driver.
Higher efficiency (97dB)
More dynamic performance than a single driver.
Will play louder than a single driver.
Will handle more complex music than a single driver and is just as fast.
Super Alnico High Output Monitor Specifications
Sensitivity: 97 dB
Impedance: 4-6 ohms
Driver: Twin Proprietary 6.5" Omega Alnico HempCones (1 whizzer, 1 dustcap)
Frequency Response: 38-20kHz
Dimensions: 24"H x 10"W x 14"D
Weight: 38 lbs. each in a shipping box
Power Requirements: as little as 2 watts
Crossover: None (coil for LF cutoff)
« Last Edit: 8 Nov 2018, 05:58 pm by peckjed »
peckjed
Bump. Will sell without stands for 2700
smccull
Wish I could buy these. Miss my Omegas!
peckjed
You COULD buy them if you wanted  :wink:
smccull
I would but I like being married.  :lol:
peckjed
Bump!
peckjed
Bump!
peckjed
Price drop to $2500 + shipping (or local pickup)
