JEMS Audio DIY Kits for High-End Audio
0 Members and 1 Guest are viewing this topic. Read 1482 times.
Foil Man
    • http://www.jemsaudio.com
« on: 16 Jan 2005, 01:00 am »
For all you do-it-yourselfers, JEMS Audio has some great new kits:
.00075 Copper Foil for DIY Speaker Cables- Here's your opportunity to build the best speaker cables you have ever heard! Whether you have horns, electrostatics, electrodynamic drivers, or ribbons, you will be amazed at the performance of this foil.
Solder-free and Metal-free Connector Kits- Most people don't realize the sonic signature that standard metal connectors bring to their music. These connectors eliminate the metal and solder allowing you to really hear your system's components.
Copper Foil and Silver Power Cable Kit- The power cable to beat is now available. It is a foil-silver hybrid design at a ridiculously low price in a kit.
Ultra-High Resolution Interconnect- This product is not a kit. As an interconnect it is extremely fast and detailed top to bottom, doesn't have the characteristic sounds of copper or silver and is extremely musical. This is a low capacitance cable, unshielded. It can also be used as internal wiring for high-end preamps and amplifiers.
For more information, please visit us at http://www.jemsaudio.com.
