0 Members and 1 Guest are viewing this topic. Read 6761 times.
After doing a little more research, it appears for me to achieve a stereo subwoofer setup with 2 subs from my single sub output on my Reciever I need a Outlaw ICBM Bass management piece correct?
I would run the subs off of the main L and R speaker outputs. This would then use the speaker level input on the sub amps and would allow the main speakers to roll off naturally.
Quote from: JDUBSI would run the subs off of the main L and R speaker outputs. This would then use the speaker level input on the sub amps and would allow the main speakers to roll off naturally.Sure, that works great for 2ch applications when using powered subs.Not quite applicable for Timothy's application though.
Has anyone done a test with stereo subs versus two subs fed the same signal (from both front right and left speakers)? I went to two subs to get stereo subs, but my Proceed AVP won't do stereo subs correctly. My Proceed AVP is supposed to put all sub info from right speakers on the right sub and all sub info from the left speakers on the left sub, and split the LFE and center channel to both subs. It does work in non-stereo modes, but in stereo, only one sub works. How much low frequency (<60Hz) ...
