***Sold***Yamaha RX-A700 A/V 7.1 receiver
0 Members and 1 Guest are viewing this topic. Read 1624 times.
jmck407
« on: 21 Sep 2018, 06:33 pm »
Nice condition (see pictures) Yamaha RX-A700 comes with  original accessories: remote, YPAO calibration microphone, and radio antenna. Tested & functional in home theater setup (see pictures), one owner. Packed well and ready to ship.  Asking $80 plus shipping from 33470.
Product Description
AVENTAGE is a dramatic, inspired step forward in audio/video component design. AVENTAGE brings studio-grade sound and sophisticated video enhancements to the home as a result of unparalleled attention to detail in design, engineering and fabrication. Details that, at first glance, would not seem to affect the quality of sight, sound and control, when brought together within an AVENTAGE component, produce a work of visual and acoustic art. The RX-A700 A/V Receiver supports 3D and Audio Return channel over 6 in/1 out HDMI, CINEMA DSP 3D, with or without Front Presence Speakers, and RS-232C interface for custom installation.
From the Manufacturer
Yamaha AVENTAGE RX-A700 Audio/Video Receiver: An Inspired Leap Forward in Home Entertainment
An elegant look with discreet but powerful front panel controls.
AVENTAGE is a dramatic, inspired leap forward in audio/video component design. AVENTAGE brings studio grade sound and sophisticated video enhancements to your home with unparalleled attention to detail in design, engineering, and fabrication. We rethought every electrical path, every part, every piece, and every material to maximize performance. Details that at first glance would not seem to affect the quality of sight, sound, and control, when brought together in an AVENTAGE component, produce a work of visual and acoustic art.
In addition to an innovative new construction design, the RX-A700 A/V Receiver supports 3D and Audio Return channel over 6 in/1 out HDMI, new GUI with overlay on HD and 3D sources, CINEMA DSP 3D surround sound, RS-232C interface for custom installation, and Control4® certification.
A Unique Approach to Enhanced Performance
Enhanced Stability: Double Bottom Construction and a Specially Designed 5th Foot (A.R.T. Wedge)
The RX-A700 fifth foot
A specially designed fifth foot adds even more stability to reduce vibration
Strong stability in an amplifier design reduces noise and jitter in your digital signal for clearer audio and video. High-grade, heavier terminals reduce vibration at the speaker connections. An additional bottom cover contributes extra support at higher volume levels for the power transformer and heat sinks. And the specially-designed fifth foot at the center of the amplifier--an Anti-Resonance Technology (A.R.T.) Wedge--improves overall structural rigidity and reduces vibration, resulting in a more stable signal and sound improvement.
Enhanced Power: Low Jitter Circuitry
Built-in Low Jitter circuitry reduces jitter from digital sources, including HDMI, using a more precise timing control--so you can be sure of a stable audio/video signal, resulting in perfectly reproduced images and sound.
A hybrid power supply makes the AVENTAGE series even more efficient. Independent power supplies for the digital and analog circuit results in less power consumption in standby mode, and a more efficient power transformer--so despite the power of the RX-A700, it could cost you less to run.
Technical Specifications
Output Power: 630 watts (90w x 7 RMS)
Impedance: 8 ohms
Frequency Response: 10Hz - 100kHz (3dB)
Total Harmonic Distortion: 0.04%
Signal-to-Noise Ratio: 100dB
HDMI Inputs/Outputs: 6/1
USB Inputs/Outputs: 1/0
Ethernet Inputs/Outputs: 1/0
Radio: AM/FM with HD Radio
Dock Terminal for Compatible Accessories: 1
Optical Inputs/Outputs: 2/0
Coaxial Inputs/Outputs: 2/0
Analog AV Inputs/Outputs: 5/1
Component Video Inputs/Outputs: 2/1
Composite/S-Video Inputs/Outputs: 5/5/1/1
RS-232C Interface: 1
Multichannel External Decoder: 8 channels
Dimensions (W x H x D): 17-1/8" x 6" x 14-3/4"
Weight: 23.1 lbs
Manual can be found at (search for the RX-700):  https://usa.yamaha.com/products/contents/audio_visual/downloads/manuals/index.html?k=&c=audio_visual&l=en&p=45
« Last Edit: 3 Nov 2018, 02:23 pm by jmck407 »
jmck407
Re: Yamaha RX-A700 A/V 7.1 receiver
« Reply #1 on: 24 Oct 2018, 12:09 pm »
Price reduced to $80 plus shipping from 33470
jmck407
« Reply #2 on: 3 Nov 2018, 02:22 pm »
AVR sold for $102 on Ebay on Thursday.
