when is capacitor esr too low oscillation
0 Members and 1 Guest are viewing this topic. Read 2349 times.
goodguys
« on: 17 Sep 2018, 06:49 am »
Hi And thanks for reading this post.
I am building an amplifier power supply and am going to parallel connect the capacitors to take advantage of lower esr.
But what is the esr goes too low and the power supply begins to oscillate, what is an easy way to tell if that problem is occuring.
Will there be a buzzing sound coming from the capacitors or from the speakers. Or will the power supply oscillate and damage the amplifer without any warning.
Many thanks.
Speedskater
  • Kevin
Re: when is capacitor esr too low oscillation
« Reply #1 on: 19 Sep 2018, 02:21 pm »
That's what an oscilloscope is for.
Anyone that modifies circuits in this way or rolls op-amps needs an O-scope.
Speedskater
  • Kevin
« Reply #2 on: 19 Sep 2018, 04:48 pm »
I just saw this sentence in a DIY forum.
Placing 0.1uF of low esr cap across the output of a regulator is a good way to invite instability, which might sound like 'brighter treble'. Its a very common mistake.
Morel: don't mess with things that are working.
