X-LS Encore build x2
0 Members and 1 Guest are viewing this topic. Read 5438 times.
Folsom
Re: X-LS Encore build x2
« Reply #20 on: 31 Dec 2018, 08:22 pm »
Nice!
lacro
« Reply #21 on: 3 Jan 2019, 07:12 pm »
Anybody have any idea why a lacquer finish would feel wavy after sanding down and what to try next?
Mike
Mike,
That seems strange after all the sanding? Could it be the veneer, and not the finish that is wavy? I like using a long board sander to flatten the panels instead of a power sander. You may have to build many more coats of lacquer to be able to sand completely smooth. Also, buffing may help smooth out the waves.
