0 Members and 2 Guests are viewing this topic. Read 17254 times.
Hi Mark,I use REW for measurements and Dirac Live, and one thing that is very evident in my room, is that when I'm running the monitors full range AND overlapping the subwoofers, it wreaks havoc on the measured (and subjective) performance in my system. My preamp has two sets of balanced outputs and two sets of single ended outputs. I think the issue (especially that the monitors are ported and the subwoofers are sealed) is that at some frequencies the monitors and the subwoofers are in phase and at some frequencies they're out of phase with each other. This causes significant peaks and cancellations in the frequency response in my system.The reason I want to add an active crossover (analog or DSP) is so that I'm not just low passing the subwoofers, but also high-passing the speakers. This also gives the speakers more headroom and lowers distortion by allowing them to play in the range where the woofer is most effective. I'm thinking that since the Rythmik subs are so good, and the servo control seems to make such a big difference with the bass frequencies, that I'll be high-passing the monitors around 80Hz-100Hz (even though they can play down to ~ 30Hz).
Nick,It seems that your entire premise for posing the question regarding digital DSP active XO vs. analog XO is your dissatisfaction with your sub/mains/room integration. As such, do you mind posting your measurements on the acoustics circle? Perhaps we can advise on some tweaks depending on how flexible your current 2ch listening situation is. And the more I learn about DIRAC the more impressive it seems although I will say there are solutions in audio that belong in the electrical domain and solutions that belong in the acoustical domain. Some acoustical anomalies can never be fixed in the electrical/DSP/DIRAC domain...Best,Anand.
I am considering the SHD, I've been asking some questions in the miniDSP forum as well. The DAC & analog output section in the SHD is surely a step down from the Esoteric, no?
As much as you like your current gear, you might want to think about selling it all and going all in on active with these guys. http://www.analog-precision.com/ They can even build the amp using Hypex models and I bet Rick would do the fade program. Also don’t forget that enjoying music and home theater is the point. It’s very easy to get caught in a perpetual upgrade/change journey and miss out on enjoying life. Audio isn’t worth making your wife angry or losing time with your kids. Just saying..,
Only a side by side listen could determine that but don't dismiss out of hand the advancements made in digital in recent years. For instance just read reviews from say 4 years ago that sound absolutely primitive by today's standards. Whatever digital you buy today will be obsolete in 5 years. That's not to say chips are everything or that build quality means nothing, but digital is disposable, so no point in paying for chiseled faceplates or other boutique bling. Analog (tubes and vinyl) are dead. BTW I moved from Dynaudio BM5 MkIIIs to JBL 708Ps a couple of months ago. I liked the Dyn's but love the 708P's, which I should for the price/size difference. So I'm in a similar boat, looking for a new DAC/preamp/DSP, so would like to love the SHD too. But as you say how good can a $500 DAC (if the $1200 price is roughly broken down for each component) be? That's why I eagerly await comparative reviews of this, and the RME ADI-2 DAC (as I've recently moved my GIK 244 panels around and have tamed the worse speaker/setup/room anomalies). The ADI-2 DAC is prosumer and should be higher build/sound quality for $100 less. And for what little correction I need, the 708Ps should be able to handle that reasonably well.
Audioscience did some measurements of the shd a couple of weeks back. Mine should be here tomorrow and I'm looking forward to giving it a shot in my system.-Jim
