Empirical Audio Offramp and Nvidia
0 Members and 1 Guest are viewing this topic. Read 3898 times.
andresz
« on: 4 Sep 2018, 10:14 am »
Hoping someone has experience here as this is a topic that is very hard to find communication on.
I have a high end system that doubles as a HT as well as 2 channel. Nagra/Tidal and Argento/Shunyata loom. I have been enjoying a fantastic SQ experience watching youtube live concerts (and those tagged "audiophile") running an NVIDIA Shield - USB to a non audiophile USB to SPDIF converter - Empirical Audio Synchromesh - Metrum Adagio Dac .
I am looking to upgrade the USB to SPDIF converter with something that befits the standard of the rig. The Nvidia is an excellent source for 2 channel PCM.
Looking at Empirical Audio Offramp 5/6. Turns out that many converters do not work given USB protocols.
Reaching out to any Empirical audiophiles who may be using Nvidia Shield as a source into a high end system based on USB/SPDIF conversion. Interested in what actually does work re signal connectivity.....
witchdoctor
Re: Empirical Audio Offramp and Nvidia
« Reply #1 on: 3 Oct 2019, 03:10 pm »
Hi, I found this thread by doing a search on Nvidia. I was wondering about using it as a streamer and the SQ and your comments are very helpful.
Re: USB/SPDIF conversion did you find anything? How is it working out?
audioengr
« Reply #2 on: 3 Oct 2019, 05:23 pm »
I'm using the OR6 now with Amazon Prime Music, what they call hi-res, but it's actually 44.1.  They have a free 90-day trial.  Sounds so good that I may subscribe.  It's only $5 a month I believe,.
Steve N.
mtruong34
« Reply #3 on: 3 Oct 2019, 05:45 pm »
Hello andresz,
It's curious that you are able to get decent audio quality out of Nvidia Shield TV. I have a similar use case as you, but I have not been satisfied with the SQ when using the Nvidia as a source. I can tell a big difference going USB out of a laptop running the same youtube video.
Please see this link as a possible cause.  https://www.nvidia.com/en-us/geforce/forums/discover/296594/audiophile-having-problems-with-shieldtv-probably-caused-by-upsampling/
Are you doing something unique or different to get such good results?
-Mike
ricmon
« Reply #4 on: 3 Oct 2019, 06:14 pm »
Hello andresz.  Will you be using a toslink for your SPDIF connections.  If so you may want to check out something like this:
https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E/ref=sr_1_1?keywords=ac+access+spdif+converter&qid=1570126398&s=electronics&sr=1-1
Ric
gio_b
« Reply #5 on: 18 Mar 2020, 01:21 pm »
Hi is possible to have a 220volts version and make
Some upgrade later ?
Win10 compatibile? Naim sudgen radford system dac compatibible?
Tks Giovanni.
P.S:sorry my fault, i do not etere post my question, we apologize.
Is not possible to contact directly empircal
Audio for some questions?
audioengr
« Reply #6 on: 18 Mar 2020, 09:28 pm »
Tks Giovanni.
Just click on the "contact us" button on any of my website pages.
