*SOLD* Vincent Audio SV 500 Hybrid Stereo Tube Integrated Amplifier
0 Members and 1 Guest are viewing this topic. Read 1413 times.
sean619
I purchased this integrated amp for a second system that never materialized. It sounds wonderful, but has been sitting in the box, so it's time to sell. It is less than a year old.
It has an optical and coax input, which is a nice feature. I have the factory box (double boxed) with factory packing material, user manual, original power cord, and original remote.
Condition is easily 9/10
I will cover Paypal fees.
Price is $645 plus shipping from 98166
Features:
Hybrid vacuum tube and solid state design
Same tube circuit as the Vincent SV-237
Front panel headphone output
Preamp output makes it a tube preamp
Digital input decodes 16-bit, 24-bit and 32-bit audio files up to 384 kHz
Front panel headphone jack
Inputs: 4 x Stereo RCA, 1 x Optical, 1 x Coax
Outputs: 1 x Stereo Rec Out, 1 x Stereo Pre Out, 2 x 3.5mm Jack (Power control), 1 x pair of speaker connectors
Tubes: 1 x 12AX7, 2 x 6N1
Wireless remote
Color: Black
Specs:
Frequency response: 20Hz – 20kHz (+/- 0.5dB) Output power 8 Ohm: 2 x 50 Watts RMS Output power 4 Ohm: 2 x 80 Watt RMS Input sensitivity: 420mV THD: < 0.1% (1kHz, 1W) Signal to noise range: >90dB Input impedance: 47 kOhm TI PCM5100-series audio DAC with 32-bit/384kHz PCM Interface Dimensions: 17" wide x 4.6" high x 14.7" deep Weight: 22 lbs.
« Last Edit: 10 Sep 2018, 05:24 am by sean619 »
