0 Members and 1 Guest are viewing this topic. Read 1842 times.
Working on my RM2s. I sent the 626 off to Danny Ritchie at GR Research and he did a great job with them. Replaced the spiral tweeters with the ribbons, and basically build me a new crossover from scratch. They sound GREAT!However, they just don't have that lower midrange transparency of the RM2s. They had issues. Channel balance was off by 8 db, room correction showed that they needed to be crossed over at 110 hz, something wrong there. I couldn't ship them but I found a local guy who had some experience, not a lot, to take a look at them. Cleaned the l-pads like crazy, fixed most of the channel balance issues. He can't find anything wrong with the crossovers so here is my plan. Keep in mind that as they were, they sounded fantastic.I am just going to leave the mid and tweeter crossover alone. Hard wire the woofers to the terminals with no crossover. I have a pair of VMPS smaller subs, with plate amps. The plates have a high pass line level crossover. I am going to use the crossover in my pre-pro, it can go up to 250 hz. I might need 280 but I hope this will be close enough. Run a cable to the plate amp, run it up to maybe 80 hz, line out from the plate amp to an external amp to drive the woofers in the RM2. Levels may be tricky, only one way to find out. I saw a previous post that mentioned schematics for the crossovers may be available. Certainly this is a case where an external crossover for the woofers might be useful.
You misunderstood. Danny did a great job. The 626 sound great! There was no way I could ship the RM2s to Texas.
