0 Members and 1 Guest are viewing this topic. Read 8714 times.
I've had the LCD-2.2 pre-fazor and the LCD-3 pre-fazor. I now have the LCD-2 Classic from last year. The comfort has been much improved over past models. The new headband is vastly better than what they used to have. The earpads are deep and plush.
The weight of the LCD-XC didn't bother me but I found the (leather) pads got uncomfortable after a while. Unfortunately Audeze discontinued the vegan pads, which I was going to buy if I kept the phones (I didn't).Not all planar magnetics are heavy, or at least not as heavy as Audeze.
So I take it you've never been bothered by their weight? From what I'm learning, because of their design, planar mags are just generally heavy HP's.I'm also thinking about the LCD-3 rather than the LCD-X, both used.Gene
Thanks.I wear my 650's a lot lately and weight is never a problem. But like you said, they do get a little hot but I take them off fairly frequently. I just have an urge to see what's out there especially the planar mag thingy.Gene
Thanks for that.So if my LCD2's are in that same range, then they will be twice as heavy as my 650's. But they're only HP's, right? Who knows? Glad to see you have HD800s's. They're on my radar just to try better Senn's.So how do you like the HD800s's?Thanks,Gene
The HD-800s are nice. I use a Woo WA-22 . The 800s are a little more detailed/accurate than the others.
