0 Members and 1 Guest are viewing this topic. Read 2562 times.
Not easy or cheap find matched quartet tubes of any model, I could sold such amp.
6CA7, EL34 and KT77 are all interchangeable. IMO the new Gold Lion KT77 sounds quite good and won't break the bank.
Is Gold Lion KT77 better than new Tungsol EL34b?
Do you could say what will be the time life of these Nesstones ?
+43 for GL KT77. Not as reliable as NOS, but it seems to be the equal of many NOS tubes as far as sound. Are the Kt77 warm sounding tube?The only issue I've had with the new Russian tubes is loss of vacuum. The getter on several of my new stock Russian tubes has turned white, it happens very quickly and usually pretty near the start of the tube's life. I think after some heat cycles some tubes seal may fail.
