Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Classic Phono vs Cornet???
0 Members and 1 Guest are viewing this topic. Read 1784 times.
Julien43
13 Jan 2005, 11:16 am »
I have purchased the reccomended chassis for the original(Classic) Phono. Can it be used for the Cornet? Other than CSS, Iron and mono switch are there other differances between the two amps?
Thanks, Julien
hagtech
Facilitator
13 Jan 2005, 06:08 pm »
Yes it can. But the 2" height makes it difficult. You'll have to file or cut one of the bottom lips in order to get board in. The Cornet(2) board is 11.65 inches and fits pretty tight into the 12" chassis. The 3" tall version works better.
In short, you can get it to fit with a little work. Standoffs need to be real short too.
jh
Eric H
Reply #2 on:
13 Jan 2005, 07:05 pm »
I tried to use the Hammond 12x8x2 chassis a while back for the Cornet(2). I wrote up some of the details here:
http://www.audiocircle.com/index.php?topic=14155
I didn't actually finish the assembly with the 12x8x2 chassis but I don't think it's impossible... (I never did figure out if there was a good way to mount the AC cord) 12x8x3 makes it a lot easier.
WEEZ
Reply #3 on:
13 Jan 2005, 09:08 pm »
..on the topic of Classic vs. Cornet 2:
Is there an assembled version of the Classic available? I see that the Cornet 2 is $995. The Classic pictured w/ wood caps looks better (IMHO) and the specs appear to be the same- actually the classic is rated a bit quieter- a few db's.
Cost?
thanks,
WEEZ
Julien43
Thanks Gentlemen!!
Reply #4 on:
14 Jan 2005, 02:24 am »
Your replies are much appreciated. With this information, I must lean towards the Classic. Thanks Again
Julien
Other Stuff
Hagerman Technology
hagtech
