M3 Turbo S from 4Ω to 16Ω. ...?
0 Members and 1 Guest are viewing this topic. Read 1536 times.
mpv
« on: 2 Aug 2018, 06:07 pm »
Hello,
Wondering if M3TS can be modify from 4Ω to 16Ω ? It seems Triode Master use same drivers apart the compression driver and different wiring.
Probably the crossover as well.
mick wolfe
Re: M3 Turbo S from 4Ω to 16Ω. ...?
« Reply #1 on: 2 Aug 2018, 07:22 pm »
Don't mean to sound like Captain Obvious, but the person with the answer is Clayton Shaw. And I'm sure his answer will be to send them in for the Triode Master modification. Sounds like an expensive option, but it keeps the speaker's value intact.....as opposed to a questionable DIY project that takes the value in the opposite direction.
