Industry Circles
Odyssey Audio
klaus@odyssey
stacking components
stacking components
0 Members and 1 Guest are viewing this topic. Read 1348 times.
vanderstephen
stacking components
31 Jul 2018, 01:56 am »
I am adding another component to my system. Based on the opening heights for the shelves and number of shelves I will have to stack something as I will be be one shelf short of the number of components that I have. If I stack my Khartago amp on top of my Tempest preamp, I'll have about 1" clearance between the top of the amp and the shelf above. Is that sufficient? I keep the amp on 24-7. My backup option is to put my DVD player on top of my preamp. Thoughts?
klaus@odyssey
Facilitator
Re: stacking components
31 Jul 2018, 04:01 am »
DVD on top of Tempest ONLY !!!!! Less PS interference and less heat
and only if you absolutely have to...always a good idea to put cones, tennis balls, wood, etc. between them to increase the distance because of PS's.....
vanderstephen
Reply #2 on:
31 Jul 2018, 04:28 am »
Thanks for the answer!
Industry Circles
Odyssey Audio
klaus@odyssey
stacking components
