Tempest HT bypass
0 Members and 1 Guest are viewing this topic. Read 1956 times.
vanderstephen
Tempest HT bypass
« on: 31 Jul 2018, 01:35 am »
Hi. I currently have a 2 channel system that I'm perfectly happy with and have no intent of changing anything. The heart of the system is the Odyssey Tempest preamp. I am in the process of also setting up a home theater this year. I bought a receiver that has pre-outs for each channel. I've had the Tempest for many years and don't have the manual. I know the Tempest has the option to have a HT bypass, but how can I tell if I have it and how do I set it up and use it? Here are images of the front and back. I am guessing the two larger posts on the back left are for this, but I have no idea.
vanderstephen
Re: Tempest HT bypass
« Reply #1 on: 31 Jul 2018, 01:36 am »
Sorry the pics are upside down, but you get the idea. :scratch:
Jonathon Janusz
« Reply #2 on: 31 Jul 2018, 02:18 am »
Unless I'm forgetting something, the larger set of RCA jacks on the back you mention are generally a second set of (variable) outputs, maybe even using a nicer RCA jack than the ones you currently are connecting your amp to.  If this is the case, you might want to try switching over to them to see if you pick up a little free performance boost?
Otherwise, to know if you have one of the inputs configured as a HT bypass (a volume defeated input that just passes full signal straight through the preamp to the outputs), if you don't have any of your original documentation, you'll probably have to give Klaus a call to see if he can look it up in his records by your preamp's serial number.  As far as I know, all of the inputs are configured as variable (volume controlled by the Tempest) by default.
You could use one of the variable inputs as-is and just turn the volume all the way up on the Tempest (letting your HT receiver control the volume) in the meantime, but you would also then have to remember to turn the volume on the Tempest back down when you are done, otherwise when you change inputs to something other than your receiver you might accidentally get blasted with max volume signal (which depending on your speakers might go badly for them if it were to accidentally happen when the wrong song is playing from whatever source you select that isn't your receiver when it happens).
Short version: without documentation to know for sure, a call to Klaus with your serial number should get you sorted out.
klaus@odyssey
« Reply #3 on: 31 Jul 2018, 04:03 am »
yup,  2nd outs...only very few Tempest have an HT BP...it
s a pain in the ass,  and you would have a sticker on one of teh inputs saying exactly that:  HT
vanderstephen
« Reply #4 on: 31 Jul 2018, 04:31 am »
Klaus,
Is it possible to have it modified to have a bypass added? Is so, what is the cost?
Dishman442
« Reply #5 on: 31 Jul 2018, 05:23 am »
Call him for pricing and a delivery estimate.
