say hello
0 Members and 1 Guest are viewing this topic. Read 670 times.
Lang
say hello
« on: 29 Jul 2018, 02:47 pm »
this is lang, i am new in here and like to learn how to set up a good audio system.
JerryM
  • Where's The Bar?
Re: say hello
« Reply #1 on: 29 Jul 2018, 06:48 pm »
Welcome, Lang.  :beer:
dB Cooper
Re: say hello
« Reply #2 on: 29 Jul 2018, 07:23 pm »
Welcome to the sweet spot
Re: say hello
« Reply #3 on: 29 Jul 2018, 08:37 pm »
Set up a "good" audio system:
Start with a decent room (not tiny, not cubic, not weird shaped) that you have at least a degree of control over (time to yourself, can setup seating/speakers where best sounding, sound isolated if house is occupied while listening).  If you can't achieve all this seriously consider headphones.
Set an overall budget.
Try to get out to shops, shows, and clubs to develop ideas of what you like (vinyl, streaming, rips, solid state, tubes, various speaker types - which can be a very personal decision) within your budget.
Gather a sampling of your favorite music that represents a wide range of what you typically listen to audition with.  Note that the best music to judge by is live/unamplified music, otherwise you're just comparing yours versus theirs, as opposed to comparing live (real) versus whatever system you're listening to.
Limit auditions to no more than 4 systems/speakers per day but take your time with ones you're interested in (this will avoid listener fatigue).  And take notes (avoid aural memory loss and forces you to really listen).
« Last Edit: 30 Jul 2018, 11:53 am by JLM »
Phil A
Re: say hello
« Reply #4 on: 29 Jul 2018, 08:41 pm »
Welcome!
Re: say hello
« Reply #5 on: 30 Jul 2018, 12:11 pm »
There's never been a better time to purchase a good audio system with digital advancements, active speaker design coming into the home, and class D amps.
Using your laptop, or even a smart phone with $35 Chromecast, you have access to ripped/streaming CD quality (thanks to Tidal) music.  Good DACs are as cheap as Dragonfly ($100).  Check out the Cheap and Cheerful Circle.
Class D technology has matured enough to be completely competitive with tubes or other forms of solid state and are cheaper, smaller, and use less electricity (generating less heat).
Active speaker design (low voltage crossover that can be very sophisticated feeding one designer picked amplification channel per driver) are more dynamic, offer flatter frequency response, and produce gobs of deep/full bass are finally making it from studios into households.  These save space (nearly impossible to see/need an active floor stander) and save buying separate power amp(s).
Very good sound can be as simple as a laptop with KEF LS50 Wireless speakers.
Re: say hello
« Reply #6 on: 30 Jul 2018, 11:36 pm »
Greetings & Welcome to AC Lang   :thumb:
Re: say hello
« Reply #7 on: 30 Jul 2018, 11:37 pm »
Welcome Lang :thumb:
tbheels
Re: say hello
« Reply #8 on: 31 Jul 2018, 02:09 pm »
Great advice. I should've done that. Years ago.
Welcome aboard, Lang.
