Dynavector 20XM VPI
0 Members and 1 Guest are viewing this topic. Read 1579 times.
slovell1
Dynavector 20XM VPI
« on: 24 Jul 2018, 10:00 pm »
Anyone have any experience with this cartridge? I bought this a couple of years ago as a broken cartridge for $100. Turns out it had a mounting screw broken off in the threaded body. I finally got the time, and the nerve, to very carefully put this thing in my drill press and drill out the offending screw. I went ahead and drilled the threads out of the other mounting hole to have a matched pair. Believe it, or not, I've still got an undamaged functioning cantilever. I know, I can't believe it myself. I'm going to be using it on my VPI Scout with my Jolida JD9 phono stage. The cart has 1mv output. I can't find much info about it on Google and Vinyl Engine doesn't even list it. Has anyone ever had this cart and could possibly give me setup advice for it?
Regards, Sam
bacobits1
Re: Dynavector 20XM VPI
« Reply #1 on: 25 Jul 2018, 12:22 am »
I don't have direct experience with that cart but, it was offered as a special with one of the vpi scout versions.I had also seen one FS.
Maybe someone else will have more info.
PierreB
« Reply #2 on: 25 Jul 2018, 12:24 am »
Maybe it will helps...
