For Sale: Source Components
PS3 with SACD converter to DSD files - Rip your SACDs - mint condition $250
0 Members and 1 Guest are viewing this topic. Read 1199 times.
ketcham
Industry Participant
23 Jul 2018, 11:13 pm »
This as a used unit sourced for SACD ripping compatibility then refurbished and modified for longevity of use. Modified coolant fans and heat sinks. All solder points re-worked and unit cleaned up. Was able to rip my entire SACD collection. Anticipate no issues for years of use.
$250.
LesterSleepsIn
Occasionally consternated
Re: PS3 with SACD converter to DSD files - Rip your SACDs - mint condition $250
24 Jul 2018, 04:30 pm »
Just pm’d you.
trueaudiophile
Reply #2 on:
24 Jul 2018, 11:13 pm »
I am defiantly interested. However I heard its pretty complicated to Rip SACD's Is it as easy as ripping PCM on a windows computer or what? Can you tell me a bit about the process?
Trueaudiophile,
ketcham
Reply #3 on:
25 Jul 2018, 04:34 pm »
The program is already loaded on. The disk image .iso is created. This is transferred to your computer and the .iso is converted to .dsf or format you choose. The software is open source and free. jriver actually reads .iso files. Then you move the .dsf files into a proper folder. Artist/album.
Select the program in PS3 and follow the instructions. I can send you the .pdf manual attachment to review. PM me.
https://www.computeraudiophile.com/forums/topic/7494-sacd-ripping-using-your-ps3-part-2/?tab=comments#comment-7494
LesterSleepsIn
Reply #4 on:
26 Jul 2018, 04:23 pm »
Hello Ketcham,
I pm’d you yesterday. Did you not receive it?
I’ll try again now.
Lester
