High quality RCA cables for Technics 1200
0 Members and 1 Guest are viewing this topic. Read 1268 times.
dkd7
« on: 17 Jul 2018, 02:56 pm »
Right now I have 4' of BJC LC1 soldered to the circuit board, I'm looking  to replace those with a much higher quality cable with relatively low capacitance.
I would like to keep my budget under $300, I believe I still want the RCA ends and not a separate RCA jack, this eliminating another connection point.
All input appreciated.
Speedskater
  • Kevin
Re: High quality RCA cables for Technics 1200
« Reply #1 on: 17 Jul 2018, 04:31 pm »
There are no higher quality cables  than the BJC LC-1 cables! (and only a few equals)
But the very low cable capacitance of the LC-1's may not be ideal for a phono cartridge cable.
dkd7
« Reply #2 on: 17 Jul 2018, 06:13 pm »
Well....not to start a cable war... :)...how would a low capacitance cable negatively affect the Technics 1200?
« Reply #3 on: 17 Jul 2018, 09:43 pm »
I guess I am a little confused. Which circuit board do you have wires connected to? I have a 1200 also. I have the tonearm wires terminating in RCA plugs that I plug into my phono preamp. I recently upgraded the wiring to cardas copper wiring.
Speedskater
  • Kevin
« Reply #4 on: 17 Jul 2018, 10:21 pm »
Many phono cartridges are rather sensitive to the total capacitance that they see. That would be the sum of the cable and pre-amp input stage. Often even with typical cables, capacitance is added to make the cartridge happy.
« Reply #5 on: 17 Jul 2018, 11:01 pm »
You are in the right way, I would post at Sonic Craft Circle, Jeff will have a wire suggestion for you:
https://www.audiocircle.com/index.php?board=201
http://www.soniccraft.com/index.php/wire-tone-arm-c-296_259
Speedskater
  • Kevin
« Reply #6 on: 17 Jul 2018, 11:14 pm »
Here is a paper on phono cartridge capacitance loading. You can skip the math parts.
http://www.hagtech.com/loading.html
