Treatment when LP is close to rear wall
0 Members and 1 Guest are viewing this topic. Read 1912 times.
mlundy57
« on: 14 Jul 2018, 02:05 am »
My LP is only 1'-2' off the rear wall. Which is better, absorption or diffusion when this close?
Mike
poseidonsvoice
    • 2 channel/7 channel setup
Re: Treatment when LP is close to rear wall
« Reply #1 on: 14 Jul 2018, 02:47 am »
Absorption.
Thick absorption, like GIK 244 or Monstertraps. You can place Alpha series versions of the 244 and/or Monster but the benefits will be small at that close of a distance.
Do not use pure diffusers like the QRD, MLS type, etc... if your listening position is that close as comb filtering can occur.
Best,
Anand.
P.S. I used GIK products just for illustrative purposes. You can use the equivalent of 4 inch thick absorption or more from other manufacturers (RealTraps, Primacoustic, Vicoustic, etc...) as you see fit.
mlundy57
« Reply #2 on: 14 Jul 2018, 04:33 am »
Anand,
Mike
rollo
  • Rollo Audio Consulting -
« Reply #3 on: 14 Jul 2018, 06:25 pm »
  Agree absorption will be your best friend.
charles
richidoo
« Reply #4 on: 15 Jul 2018, 03:18 am »
BAD panel is better than absorption for nearby surface.
DIY
« Reply #5 on: 15 Jul 2018, 03:41 am »
Personal taste aside in my experience with planars are they like live rooms and dynamic speakers sound better in stuffed rooms.
poseidonsvoice
« Reply #6 on: 15 Jul 2018, 10:50 am »
DIY
GIK’s Alpha Panels mentioned above attempts to do the same by minimizing high frequency absorption above 1khz.
http://www.gikacoustics.com/product-category/alpha-series/
Best,
Anand
