Cheap sound card with perfect digital out
0 Members and 1 Guest are viewing this topic. Read 2547 times.
jermmd
« on: 11 Jan 2005, 11:30 pm »
This discussion on Anandtech might be of interest to people:
http://forums.anandtech.com/messageview.aspx?catid=40&threadid=1440808&enterthread=y
Basically, this $24 card can be flashed for bit perfect digital out.  The analog out is crap but if you're using an external DAC/processor, the PC will make an exceptional transport.
Unless you want to use your PC for gaming and video, a cheap PC (such as a Dell 420SC) this card and a big hard drive will give you a really great transport for under $500.  A good video card and a DVD burner can be had for another $300.  An arguably superior transport and DVD player with all the PC extras (internet, office functions, games etc.).  There is the usual hassle concerns, but I think this is the future.
Joe M.
ted_b
« Reply #1 on: 11 Jan 2005, 11:42 pm »
I have this card, and I will tell you that the analog outs are not crap; they aren't Lynx quality, but they best most average cards or gaming-type cards (Audigys, etc) for 2 channel audio  The fact that this card is bit-perfect, and has a decent 24/96 dac in its own right, and is $25, is tough to swallow.  Lots written and good support over at the computer-as-source forum at headfi.org, including setups, etc.  This card has some idiosyncrasies, but once past them in setup and you're golden.
Edit:  BTW, I never needed to flash my card to get bit-perfect.
Ted_B
jermmd
« Reply #2 on: 11 Jan 2005, 11:49 pm »
Ted_B.
I stand corrected.  I only know what I have read about this card.  How do you know if digital output is bit perfect?  Is my Audigy 2 cards' digital out bit perfect?
Joe M.
ted_b
« Reply #3 on: 12 Jan 2005, 12:04 am »
The bit perfect test is a bit (pun) goofy, but is described over at head-fi.  Basically, you need to find a DTS reciver and a DTS sound file.  If your dig output passes it, it's bit perfect.  The instructions and files are over at head-fi.  Try this for starters:
http://www4.head-fi.org/forums/showthread.php?t=83397&highlight=perfect+dts
Also, I'm not saying that flashing the Prodigy drivers aren't worth it, just that my native card passed without it.  I guess the Prodigy drivers are more stable, etc.
Audigy cards output an upsampled 48k, which is not bit perfect of course.  I guess there are ways to get around this with mods or flash eproms, but I don't know how.  Search head-fi computer-as-source forum again for that info; it's there.
Edit:  I don't use the Chaintech for my home audio, BTW.  I use it for computer audio and for my headphone amp (Senn HD580's).  The analog audio is very good, though.
ted_B
Marbles
« Reply #4 on: 12 Jan 2005, 12:12 am »
Ted, how do you think it would do in your home audio system feeding a standalone DAC?
jermmd
« Reply #5 on: 12 Jan 2005, 12:59 am »
Wow did my computer fail the bit perfect test! Thanks for the link.  Can DTS DVD's be played over the computer using this card?
Joe M.
ted_b
« Reply #6 on: 12 Jan 2005, 01:30 am »
Quote from: Marbles
I've used it feeding my Scott Nixon DAC (which will go on Audiogon or here asap) and it sounded great.  I used flac files from my hd, through foobar.  For a myriad of other reasons I went the Modwright 999ES route, though (for this discussion, it's truly irrelevant; i.e wasn't related to sound quality, per se).
Ted
Marbles
« Reply #7 on: 12 Jan 2005, 04:00 pm »
I see it has an optical digital out, does it have a coax digi out?
