SOLD: Yamaha AS3000
0 Members and 1 Guest are viewing this topic. Read 1898 times.
Maleficio
SOLD: Yamaha AS3000
« on: 1 Jul 2018, 04:01 pm »
Up for sale is my wonderful Yamaha AS3000. This integrated amplifier has served me well for almost 2 years now; I am the first owner. Condition is excellent, as it has not moved from its rack since day one. Can power practically any type of speaker and the sound is glorious. If you are within the tri-state area (ZIP:06811), pick up would be preferred considering the amp's weight. I have long disposed of the original packaging but I can pack it appropriately should shipping be necessary. The remote is included and if I find the manual, I'll include it as well.
SOLD
Features:
A-S3000 Technical Features
- Integrated phono stage (both MM & NC)
- Integrated headphone amp (high quality)
- Can be used with another amp and act as a Pre or
- Can be used as a amp for another Pre
- Both balanced or single ended support
- Dual amp posts for pure bi-wiring
Maximum Power:
(8 ohms, 1 kHz, 10% THD) 130 W + 130 W / (4 ohms, 1 kHz, 10% THD) 210 W + 210 W
Minimum RMS Output Power:
(8 ohms, 20 Hz-20 kHz, 0.07% THD) 100 W + 100 W / (4 ohms, 20 Hz-20 kHz, 0.07% THD) 150 W + 150 W
Dynamic Power/Channel:
(8 / 6 / 4 / 2 ohms) 120 / 150 / 200 / 300 W
Damping Factor (8 ohms, 20 Hz-20 kHz) 250
Input Sensitivity/ Impedance:
CD 200 mV / 47 kilohm, Phono MM 2.5 mV / 47 kilohm, Phono MC 100 μV / 50 ohms, Main in 1 V / 47 kilohm
Frequency Response:
CD, etc. to speaker out, Flat position 5 Hz-100 kHz +0 dB / -3 dB, CD, etc. to speaker out, Flat position 20 Hz-20 kHz +0 dB / -0.3 dB
RIAA Equalization Deviation:
Phono MM (20 Hz-20 kHz) ±0.5 dB / Phono MC (20 Hz-20 kHz) ±0.5 dB
Total Harmonic Distortion (20 Hz–20 kHz):
CD balanced to speaker out 0.025% (50 W / 8 ohms), CD, etc. to speaker out 0.025% (50 W / 8 ohms), Phono MM to Rec Out 0.005% (1.2 V), Phono MC to rec out 0.02% (1.22 V)
Signal-to-Noise Ratio [IHF-A Network]:
CD, etc., (200 mV, Input Shorted) 103 dB, Phono MM (5 mV, Input Shorted) 93 dB, Phono MC (500 μV, Input Shorted) 85 dB
Residual Noise:
CD, etc., IHF-A-Network
Channel Separation (1 kHz/10 kHz):
CD, etc., Input 5.1 kilohm Terminaled 74 dB / 54 dB, Phono MM, Input Shorted, Vol: -30 dB 90 dB / 77 dB, Phono MC, Input Shorted, Vol: -30 dB 66 dB / 77 dB
Tone Control Characteristics:
Bass Boost / Cut (at 50 Hz) ±9 dB, Bass Turnover Frequency 350 Hz, Treble Boost / Cut (at 20 Hz) ±9 dB, Treble Turnover Frequency 3.5 kHz
Audio Muting:
-20 dB (approx.)
Load Impedance:
If you use two sets (A and B), the impedance of each speaker must be 8 ohms or higher.
Dimensions:
(W x H x D) 17-1/8” x 7-1/8” x 18-1/4”
Weight:
54.2 lbs
Feedback:
https://www.audiogon.com/users/maleficio/feedbacks
https://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=maloficio
http://www.head-fi.org/t/230158/maleficio
https://www.usaudiomart.com/userfeedback.php?user_id=68758
« Last Edit: 14 Aug 2018, 02:26 pm by Maleficio »
Maleficio
Re: FS: Yamaha AS3000
« Reply #1 on: 16 Jul 2018, 03:38 pm »
bump.
Maleficio
« Reply #2 on: 26 Jul 2018, 09:34 pm »
bump.
Maleficio
« Reply #3 on: 11 Aug 2018, 01:02 pm »
bump.
blefebvre
« Reply #4 on: 14 Aug 2018, 12:03 am »
The most-recent-era Yamahas are pretty sweet amps - I sometimes don’t think they get the love they deserve. GLWS.
