SOLD! Coral Flat 10S drivers (price reduced) drivers shipped for 320.00
0 Members and 1 Guest are viewing this topic. Read 1617 times.
Whitese
I love these guys, but they need to go to generate some dollars.
I will only ship the drivers. Whole speakers can be picked up if so desired in North Bergen, NJ.
If you have tubes you will love these drivers...I did not rock with them, their duty was Lute music via SET amp or ELL80  or ECL82 amp.
Model                                          25 cm double cone, full range speaker
Nominal dimension                        25 cm (10 ")
Impedance                                  8 Ω
The lowest resonance frequency (fo)    35 Hz
Program source input                40 W
Output sound pressure level      102 dB
Playback frequency band    fo       ~ 20 kHz
Air gap magnetic flux density      12,000 gauss
Qo                                                0.5 (35 Hz)
Equivalent mass                        17.5 g
External dimensions    Diameter      302 x depth 105 mm
Baffle opening size                        226 φ mm (Prominent 265 φ mm)
Mounting hole position dimension    240 φ mm (Prominent 281 φ mm)
Magnet weight                                750 g
Gross weight                                2.8 kg
« Last Edit: 2 Mar 2021, 01:37 am by Whitese »
Whitese
Re: FS: Coral Flat 10S drivers
« Reply #1 on: 18 Jul 2018, 04:45 am »
BUmp.
Whitese
« Reply #2 on: 22 Feb 2021, 05:22 pm »
Price reduction 350.00
