Lowcost woofer with Supravox 215
0 Members and 1 Guest are viewing this topic. Read 7030 times.
MJK
    • Quarter Wavelength Loudspeaker Design
Re: Lowcost woofer with Supravox 215
« Reply #20 on: 2 Jul 2018, 12:25 am »
The Electrovoice driver has too low of a Qts for an OB speaker.
The two Fane drivers look very similar to the Eminence Alpha 15A or Beta 15A only more expensive. I don't see any advantages.
My original recommendations still look good to me, better than the other drivers mentioned. Low cost and can be passive, design the system using BASTA.
gug42
« Reply #21 on: 2 Jul 2018, 11:58 am »
hello,
Thank you :)
Ok now I need times to work on simulation ... and more time too build and test    :thumb:
pompon
« Reply #22 on: 9 Aug 2018, 04:16 am »
Here a mesurement I made tonight between
15inch Siare NDH15-3 and 12inch Supravox 285gmf
Same baffle, same volume, same position ... same except the woofer.
JohnR
« Reply #23 on: 14 Aug 2018, 11:38 am »
Cool. So... what's the conclusion? :)
pompon
« Reply #24 on: 21 Aug 2018, 12:44 pm »
I certainly have a short acoustic circuit. The fall in the bass is not normal and to the ear, the 15-inch sounds more hollow with more impact.
I would expect to see a difference in the measurements when this is not the case.
What I was looking for was to have a nervous and dynamic hp with a nice transparency and I find that with the supravox.
For bass, my test is inconclusive. I would have to work the acoustic short circuit to have something more credible at the bottom.
