Audio/Video Gear and Systems
Planar Circle
SteveFord
Magepan 30.7 Review
Magepan 30.7 Review
0 Members and 1 Guest are viewing this topic. Read 1249 times.
jhm731
Restricted
Magepan 30.7 Review
26 Jun 2018, 07:58 pm »
http://www.hifiplus.com/articles/magnepan-307-fourpanel-dipolar-planar-loudspeaker-system/
SteveFord
Facilitator
Re: Magepan 30.7 Review
26 Jun 2018, 09:57 pm »
So which of you guys are going to step up to the plate and buy a set for review?
I would need to gofundme page so that leaves me out.
Pryso
Reply #2 on:
26 Jun 2018, 11:59 pm »
And I would likely need more than a gofundme page to afford a new home with an appropriate sized room in SoCal as well as the speakers.
josh358
Reply #3 on:
27 Jun 2018, 01:30 am »
Check out Robert Paterson's "The Book of Godesses," mentioned in the review. I'm listening now on Tidal and while the music is best described as innocuous, the imaging is quite as 3D as Chris Martens says it is -- probably more on the 30.7's!
Planar Circle
SteveFord
Magepan 30.7 Review
