300 pass thru socket
0 Members and 1 Guest are viewing this topic. Read 1220 times.
skite30
« on: 26 Jun 2018, 06:36 pm »
I have a 300b amp that the sockets r recessed into the chassis.  I want to try sme other tubes but they dont fit because their diameter is too large.  Is there a pass thru socket so I can raise the level and and use the larger diameter tubes?
Re: 300 pass thru socket
« Reply #1 on: 26 Jun 2018, 06:45 pm »
Yes there is, usually is a socket converter to other tube type no for the same tube, but you may buy some sockets and DIY:
http://www.goodcomponent.com/products/vacuum-tube-soket/tube-socket-convertor/c-74/
randytsuch
« Reply #2 on: 26 Jun 2018, 06:47 pm »
Deleted, not the right part :(
« Reply #3 on: 26 Jun 2018, 09:56 pm »
What is the tube you want insert?
JakeJ
« Reply #4 on: 26 Jun 2018, 10:37 pm »
Generally they are called "socket savers".  I ran one search but nothing for 4-pin tubes came up.
Good Luck.
skite30
« Reply #5 on: 27 Jun 2018, 11:58 am »
Ia 300b.  I dont want to convert just want to extend it.
Thanks I wasn’t finding anything either.
« Reply #6 on: 27 Jun 2018, 05:42 pm »
Seems most 300Bs have the same base and pins,
but this hobby can be strange occasionally.
