My Bryston BP-26 power supply: diference in sound plugged in Technical vs normal
0 Members and 1 Guest are viewing this topic. Read 5922 times.
Elizabeth
« Last Edit: 25 Jun 2018, 04:47 pm by Elizabeth »
CanadianMaestro
how would a power cord alone improve SQ ?  :scratch:
Elizabeth
« Last Edit: 25 Jun 2018, 04:45 pm by Elizabeth »
fredgarvin
Are the Technical outlets conditioned and the Normal not?
CanadianMaestro
If you don't know how a wire can change SQ, then I cannot teach you, nor assist your discoveries in this area. Suggest you google your question.
not just any wire...a power cord. how?
especially plugged to a wall outlet.  :scratch:
Elizabeth
Elizabeth
rob80b
With my rats nest I’m probably the least qualified to answer but Hans here has a few words regarding the topic.…
https://www.youtube.com/watch?v=5lHPjcXhK4c
https://www.youtube.com/watch?v=CV-ItoWRpQw
adol290
Elizabeth,
How many hours do you have on the power cord.
Depending on the cord i find it can take at least 200+ hours to settle in. Also during that
 time if find the sound signature changes quite a bit.
CanadianMaestro
thanks, rob. good stuff.
(LOL at first, I thought it was Clever Hans, the infamous equine.....)
Speedskater
  • Kevin
Well it's possible and very situation specific, and highly unlikely.
It comes down to EMI/RFI noise/interference and poor hi-fi component design.
Or a defective power cord or incorrect technical power system.
CanadianMaestro
Seriously? This is too much.  :lol:
The function of a pc is to pass current from A to B. Why does it need to "settle in" to function properly?
CanadianMaestro
Ahhh so... a pc blocks EMI/RFI noise. Genius. Who would've imagined that?  :duh:
We're talking Bryston amps here, right?  :thumb:
cheers
adol290
It is obvious that you must suffer from one or more of the following problems.
1. You do not have a system sensitive enough to hear the difference.
2. Your hearing is bad.
3. Like Hans Beekhuyzen says you take a shower and put on the same underwear all the time.
Elizabeth
Thanks adol290.
CanadianMaestro
None of the above. But it's clear (to me) that you have drank tons of Kool Aid.
So what is the point of this thread? To point out that somehow, a particular BP-26 (which is a superb piece of kit) may have a faulty power/noise regulation circuit that is somehow eliminated by a power cord? (I have no problem with people posting sensory observations btw. Just that some claims seem to stretch credibility given the engineering principles out there).
cheers
zoom25
A passive power cable cannot improve the power that is already on the line in series with the wall. Correct?
Although, a shielded cable might reduce the stuff getting in (shield connected to the plug at the wall) or going out (shield connected to the chassis), which might be a factor in the local environment with the nearby interconnects. The shielded cables with shield connected to both ends would be problematic (this is what I had). Correct?
So I want to ask how do people pick which shielded designs they pick for their gear. What's the reasoning for choosing one over the other? How do you know which one to go with for a particular equipment?
I want to know if there is any engineering drawback with either of these shielded cable designs for audio purposes? Are they more prone to picking up stuff? Is that why some of these premium shielded cables are advocated with a minimum or optimal length?
I see a few high end companies like Linn that advocate against using third party cables and just using their stock cables as it's voiced with them and they prefer that. I see the same with Naim. Forget expensive cables, but at the very least wouldn't top companies at least ship with stock shielded cables if they thought it made a difference at all, or a difference for the BETTER?
I still haven't gotten clarification on this topic to my satisfaction. I'd like these answered.
Lastly, I would like to see or do blind tests:
1) Is any difference noticeable?
2) If a difference is noticeable, which cable is 'preferred' or thought as the more correct sounding one?
Elizabeth
Thanks guys, the whole thing has been fun. Sadly I have no interest in your crap. I suggest you start a toilet paper thread, where you can discuss your shit on your own time.
Sorry James Tanner about clogging your circle with this drivel.
PLEASE send it all to Hell as soon as possible.
CanadianMaestro
some valid queries, zoom.
apparently the metal of the wall plug blades may influence the SQ. Red copper vs rhodium vs brass etc etc
Not sure how, though.
CanadianMaestro
You're welcome.
No interest? Then don't read the posts. Change the channel.
cheers
