0 Members and 1 Guest are viewing this topic. Read 10280 times.
This is one of the prob from manufactured speakers they use low efficiency speakers, one 6C33 can easily driver any 96dB speaker.
Not if the impedance swings from one extreme to another. There isn’t a SET amp that will sound half as good as a $20 Class D amp with my speakers - which are 95 dB sensitive. How do I know? Been there, done that. I even gave a cheap amp away to a perfect stranger forum member to prove my point. He didn’t believe me until he received the amp ... shortly thereafter he disposed of his beloved 300b and went SS. Another member with the same speakers ditched his Audionote SET after being positively gobsmacked by the superiority an older SS Krell integrated amp. YMWNV in this regard.
These are not extraordinary claims. And impedance swings are not necessarily exclusive to, or an inherent byproduct of crossovers. You know FRM, I was once like you, enslaved by ignorance. It’s a heavy yoke to bear, but enlightenment will set you free.
Tube amps work well with speakers that are not a difficult load...Tube amps do best with high efficiency speakers with flat impedance. Again, this is basic system matching stuff.
