Magnepan MMGW/MC1 placement question
0 Members and 1 Guest are viewing this topic. Read 1047 times.
veloceleste
« on: 20 Jun 2018, 02:32 pm »
Thinking of trying these in a second system mostly because of WAF. The speakers would be mounted on an entertainment center that is not centered on a wall because of a window. One side of the entertainment center is about 2.5 feet from a corner and the other side is about 5.5 feet from the other side wall. Will the close proximity to the corner of the one speaker noticeably throw off the balance or is it much less of a factor with dipole speakers? I would be adding a small sealed woofer of some sort. Thanks.
SteveFord
Re: Magnepan MMGW/MC1 placement question
« Reply #1 on: 20 Jun 2018, 11:31 pm »
With the MMGWs I don't think it'll be that big of a deal if they're not centered.
It won't be perfect but I don't think it'll drive you crazy, either.
