Fix apps that are blurry?
0 Members and 1 Guest are viewing this topic. Read 1697 times.
« on: 14 Jun 2018, 08:18 pm »
What exactly means this warning? on W10 Creators.
This window was a bit vague to me.
audio.bill
Re: Fix apps that are blurry?
« Reply #1 on: 14 Jun 2018, 10:50 pm »
Do you run multi-monitors? I've never seen that notification myself but it appears to indicate an issue with your main display resolution and the supported resolution of some of your apps. I don't see any risk in accessing the settings to see if any of the flagged apps are ones you use, and if so then you can try their suggested setting changes.
« Reply #2 on: 14 Jun 2018, 11:03 pm »
Yes i use two monitors. I will see what there are on settings.
Gracias
Well there is this image below, however I have not see any blurry app.
« Reply #3 on: 15 Jun 2018, 12:04 am »
I pressed ON bottom and restarted W10,
have noted no difference in various apps :scratch:
