DC iPurifier2 - In Pursuit of Silence
0 Members and 1 Guest are viewing this topic. Read 6989 times.
TF1216
« on: 7 Jun 2018, 07:51 pm »
In pursuit of silence – DC iPurifier2
Introduction
Listening to music on your home system should sound perfect but chances are it doesn’t, and that’s due to hiss and distortion created by the power supply connected to your electronic device.
In February 2016 iFi launched the original DC iPurifier to combat these issues and it proved to be both highly effective and popular. Not a company to stand still, iFi has now developed the DC iPurifier2 with a few new additions.
Active noise cancellation
In its 2ndgeneration, the DC iPurifier2 has a further optimised version of its much-acclaimed and award-winning ANC® (Active Noise Cancellation) system adapted from military radar defence technology. Emulating the way in which air defence radar technology works, the DC iPurifier2 identifies noise frequencies then generates identical but opposite frequencies, which actively cancel all the incoming noise.
Just insert the DC iPurifier2 between the existing noisy power supply and the device you want to use – it could be anything from a DAC to a DAW (digital audio workstation) – and the noise will be reduced by a factor of 316x to 100,000x.
Ultra wide-band design, effective from 1Hz to above 5GHz
The DC iPurifier2 is a ground-up, ultra-wide band design that leaves no stone unturned. Though it’s effective from 1Hz all the way up to 5GHz, the strongest performance is in the audible range of 20Hz to 20KHz.
Built-in polarity protection
A red protection LED will be lit if the input polarity is reversed.
  • Panasonic SP-Cap Polymer Aluminium Capacitors with an ultra-low ESR (Equivalent Series Resistance) and excellent noise reduction as well as stable temperature and frequency characteristics.
  • High-precision MELF resistors - Metal electrode leadless face resistors have excellent accuracy, stability, reliability, and pulse load capability.
    Custom Operational amps with ultra-low noise and fast speed.
  • New copper-alloy shielding - This excellent EMI shielding isolates devices and cables to block radio frequency electromagnetic radiation.
Pure Obsession
The DC iPurifier2 handles 5 volts right through to 24, and comes with a variety of adapter sizes making it compatible with all power supplies - 5.5x2.1mm, 5x2.5mm, and 3.5x1.35mm.
The retail price of the DC iPurifier2 is US$99 (ex-tax) or €119/£99 (incl. VAT).
« Last Edit: 10 Feb 2021, 09:12 am by TF1216 »
witchdoctor
Re: DC iPurifier2 - In Pursuit of Silence
« Reply #1 on: 22 Oct 2018, 02:46 pm »
Hi, I am looking at the iPurifier and some other power products on your website. Here are the devices I am looking to upgrade and need your advice as to which product is the best fit:
1) Netgear C6300 Modem/Router- uses a wall wart power supply
2) Aftermaster Pro- Uses a USB power supply  https://aftermasterpro.com/pages/learn
3) Amazon Firestick
So DC iPower? iPurifier? Combo? Thanks
BTW, do you sell any DAC's or processors that use an HDMI connection? Thanks
iFi David
  • iFi audio NEO Stream is here!
    • iFi audio
« Reply #2 on: 13 Feb 2019, 12:03 pm »
Firstly, huge apologies that no-one answered your question.
If you still need advice, please feel free to contact us on https://support.ifi-audio.com/. Our guys live for these kinds of question and would love to help you out.
Regards, iFi.
witchdoctor
« Reply #3 on: 13 Feb 2019, 01:56 pm »
Regards, iFi.
Thanks, in the future I can always contact support but if you post answers here it might help other members with the same questions in the future.
rollo
  • Rollo Audio Consulting -
« Reply #4 on: 13 Feb 2019, 06:21 pm »
WOW ! That sounds like a great product to try. Love the specs. Sell lots.
charles
iFi David
    • iFi audio
« Reply #5 on: 14 Feb 2020, 11:09 pm »
charles
