Br-2 remote and BP-25
0 Members and 1 Guest are viewing this topic. Read 1194 times.
Dloines
« on: 2 Jun 2018, 08:43 pm »
just bought my good friends BCD-1 (he is buying a BCD3) and it came with the BR2 remote, no problems controlling the BCD-1 and my BDA-2, but having a problem coding the remote to control the BP-25, the users manual does not list a 3 digit code for the BP-25?  does anyone know the code?  Thanks!
won ton on
Re: Br-2 remote and BP-25
« Reply #1 on: 2 Jun 2018, 09:23 pm »
You can try the code for the bp-26 which is 721,b60 itegrated722 or b100 int.712.My manual does not list the bp-25,hope that helps.
Dloines
« Reply #2 on: 2 Jun 2018, 10:24 pm »
thanks, tried those 3 but no luck
rob80b
« Reply #3 on: 3 Jun 2018, 10:29 pm »
I would try it again..pretty sure its's the same code and I always used my BCD-1 remote with my BP25....make sure you follow the instructions
"To program the BR2 remote control to operate other Bryston models follow these steps:
    1st)
Press and hold the CODE button on the BR2 remote until the red LED begins to flash (usually takes about 5 seconds).
    2nd)  Once the red LED remains steadily lit enter a three digit code as follows:
    711 : SP2 PreAmp/Processor
    712 : B100 integrated amplifier
    721 : BP26 preamp and BP25"
http://www.bryston.com/PDF/Manuals/300014[BCD1].pdf
