MIT Z Cord II -AC Power cable w/ Dual Noise and distortion Filtering
0 Members and 1 Guest are viewing this topic. Read 4194 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
I bought and  received a bunch of cables to play around with ( it's a strange SUB-hobby of Audio), so that means it's time to move some of the one that were in my system on to a new owner (AKA the Circle of Audio Addiction Life)
FOR SALE  MIT Z Cord II -AC Power cable w/ Dual Noise and distortion Filtering
From the MIT Z Series Brochure:
The Z-Cord II provides double filtering, which removes more noise and distortion, and offers a second set of filters, filtering over a broader bandwidth. The Z Cord II is particularly effective for eliminating power line noise emitted from digital components.
With power comes noise. The very power it takes to drive your audio (or home theater) system can have a damaging effect on audio and video fidelity by allowing noise pollution into your system. It is the quality of the power that counts. Most audio and home theater equipment (in the US) is designed to function at 120 volts at a frequency of 50 –60 Hertz. Usually, power lines feeding AV components not only carry usable frequencies (50-60Hz), but also carry frequencies above and below this operative range. It’s those uninvited frequencies that inject distortions directly into the audio and video path. This results in distortions you can see and hear. Generally, most appliances plugged into your walls are not sensitive to these problems. When it comes to lights or the refrigerator, the quality of the power does not really make an operational difference. Because of that, normal household power is not stabilized, filtered or conditioned—certainly not for precision audio or video equipment. The higher the fidelity, the more noticeable AC distortions become.
The Z Series of power products from MIT uses patented parallel “AC Filterpoles”™; a tuned LCR technology. MIT Filterpole technology eliminates reflections by efficiently absorbing all forms of AC noise from the mains, and then converting it into harmless thermal heat. The result? Once the Z circuitry is working to clean, condition and protect your AV system, you will instantly enjoy “blacker” blacks, better color saturation, and increased shadow detail; movie sound tracks will deliver dialog, Foley sounds and background music with theater-like quality. Because your audio system now has a lowered noise floor, you will have pinpoint audio image placement within a lifelike soundstage, all with clear and authoritative bass.
I have 2 for sale  roughly 2m length +/-
*** “Upgraded Hospital Grade Connector installed - so cable is shorter by a couple of inches on the PLUG end to accommodate the upgraded connector.”
  Price is $145 shipped per cable.
