LDR3.V25 vs LDRx
0 Members and 1 Guest are viewing this topic. Read 2797 times.
jstat
LDR3.V25 vs LDRx
« on: 27 May 2018, 11:08 pm »
Apart from the larger case size and cosmetics, how does the LDRx differ from the LDR3.V25?
Re: LDR3.V25 vs LDRx
« Reply #1 on: 28 May 2018, 12:08 am »
What brand they are?
« Reply #2 on: 28 May 2018, 12:14 am »
I will move this topic to Tortuga Audio Circle.
https://www.audiocircle.com/index.php?board=85
tortugaranger
    • Tortuga Audio
« Reply #3 on: 28 May 2018, 01:26 pm »
There's essentially no difference but for the physical size/appearance. The LDRx case was developed to accommodate the balanced LDRxB which need more rear panel room. The LDRx became the single-ended version. The LDRxB is being updated to the LDRxB.V25.  I'm considering retiring the LDRx model since it's largely redundant to the LDR3.V25.
