Unable to Link a Windows share to a BDP-1
0 Members and 1 Guest are viewing this topic. Read 1601 times.
swsmith7648
« on: 20 May 2018, 03:39 am »
I am now having trouble linking my BDP-1 to a PC running Windows 10 which is setup for file sharing and (hopefully) will act as a NAS.  It is strange because I was previously able to make this work, but now the BDP just won't connect up over the ethernet.  If anyone has expertise or experience in this area, I would love to hear from you.
I would also like to know what NAS units (Synology, Western Digital etc.) will work well with a BDP-1.
Thanks a lot.....
Grit
  • - Garrett
Re: Unable to Link a Windows share to a BDP-1
« Reply #1 on: 20 May 2018, 09:28 pm »
Windows update perhaps? Try googling "Samba share windows 10".. you should be able to find the registry entry to turn it back on.
unincognito
    • bryston.com
« Reply #2 on: 22 May 2018, 06:12 pm »
Please take a look at this, Microsoft has been disabling old versions of the file sharing protocol in Windows 10.
https://support.wdc.com/knowledgebase/answer.aspx?ID=20736
Chris
 :popcorn:
