Greeting from the south
0 Members and 1 Guest are viewing this topic. Read 1119 times.
Yossarian
« on: 18 May 2018, 11:45 am »
Hi All,
New to the forum but have been into Audio for last few years and two and a half years ago made the plunge albeit into an AVR and 5.1 system.
Since then I have replaced my speakers once (all zone stereo not a good idea with an 80watt avr) and my AVR three times (X1200, X2200 and finally x4300h) last one was due to upgrade with warranty replacement.
I currently run the Denon X4300 with Dali Ikon 5 mk2 floor standers and Dali Ikon vocal center and two zenzor 3's as surrounds. I use an SVS SB2000 as a sub.
My most recent upgrade was making my own Subwoofer decoupling plinth with 30mm granite and some sound isolation foam which yielded pretty good results, i made the same for my floor standers and while there is a difference not sure if its because my tweeters are ear level, or my speakers are de-coupled.
Great to be here
Yossarian
Re: Greeting from the south
« Reply #1 on: 18 May 2018, 12:54 pm »
By South i mean South Africa
Blackmore
« Reply #2 on: 18 May 2018, 01:25 pm »
Welcome to Audio Circle
« Reply #3 on: 18 May 2018, 01:29 pm »
Welcome!  Now that's south.   :green:
What are you using for source(s)?
« Reply #4 on: 18 May 2018, 01:46 pm »
Greetings & Welcome to AC Yossarian   :thumb:
Yossarian
« Reply #5 on: 18 May 2018, 01:59 pm »
Hi,
I am using the AV receiver built in Heos Module to stream Tidal and some Flac files stores on my PC with Plex.
I also use Spotify for playlists and music discovery.
For Video is now only use a Nvidea shield and Plex again for some movies
Phil A
« Reply #6 on: 18 May 2018, 02:18 pm »
Welcome!
JakeJ
« Reply #7 on: 18 May 2018, 02:51 pm »
Hello and welcome to AC, Yossarian.
Wind Chaser
« Reply #8 on: 18 May 2018, 03:24 pm »
Welcome, I’ve done the same thing to deliberately achieve both objectives.
« Reply #9 on: 18 May 2018, 10:00 pm »
Welcome aboard Yossarian :thumb:
Why the south is south?
