Quad 2905 logo
0 Members and 1 Guest are viewing this topic. Read 2482 times.
liffy99
Quad 2905 logo
« on: 15 May 2018, 08:25 am »
Dont suppose anyone knows how to check / replace the neon bulb in the Quad logo on a pair of 2905s ?
Speaker works perfectly but cannot turn on or change the brightness of the logo.
Can the badge be removed from the front ? Is it safe to do so ? Or does the speaker have to be partially dismantled ?
molar33
Re: Quad 2905 logo
« Reply #1 on: 16 May 2018, 05:19 am »
You do need to remove the wood top trim. Then remove the metal side trims.  After that remove the front steel perforated grille by unscrewing about 16 small metal screws.  A small PC board can be found attach to the back of the front grille.  Wire cable to the PC board may have come loose.
liffy99
Re: Quad 2905 logo
« Reply #2 on: 16 May 2018, 03:42 pm »
Thanks Molar33
Eeek, so complicated for a loose wire or bulb.
I’ll take a look - is it obvious how the trims are removed and is doing all this in danger of mucking up the grille cloth ? Guess I had better let them discharge overnight too.
molar33
Re: Quad 2905 logo
« Reply #3 on: 17 May 2018, 04:42 am »
 Velcro like strips are use to attach grille cloth so you should be okay.  Take your time removing the black sheet metal screws.  They can easily strip and are pain to remove.  Also careful not to damage the dust cover while removing the grille.
liffy99
Re: Quad 2905 logo
« Reply #4 on: 17 May 2018, 08:18 am »
But how do you remove the top trim and side bars ? Must admit I am getting cold feet about doing this. Perhaps I should just leave it until the time the Quads may need a service.
molar33
Re: Quad 2905 logo
« Reply #5 on: 26 May 2018, 10:53 pm »
You can use a butter knife wrap in tape so you will not scratch the top trim.  Wedge the knife in between the trim and side bars to lift the trim up.  After removing the trim,  remove the side bars by removing a couple of phillip screws and nuts.  Not hard at all.
Don_S
Re: Quad 2905 logo
« Reply #6 on: 27 May 2018, 07:36 pm »
I used suction cups to get the top decoration panel off.  Took some pulling but it worked using two cups at the same time.  I used the largest I could find that were not too large to make a tight seal (i.e. they did not lap over the edge of the trim).
molar33
Re: Quad 2905 logo
« Reply #7 on: 30 May 2018, 10:10 pm »
Great idea :D
Don_S
Re: Quad 2905 logo
« Reply #8 on: 30 May 2018, 10:52 pm »
I used inside type suction cups but I wonder if the smallest auto-body repair cups would be too large.
