0 Members and 1 Guest are viewing this topic. Read 10440 times.
Whats a good amp that puts out around 15/50w for someone on a budget (A highschooler's budget)? I was looking at the 25w Stereo Hybrid Tube Amp from Monoprice https://www.monoprice.com/product?c_id=109&cp_id=10919&cs_id=1091903&p_id=13194&seq=1&format=2#qaTab.does anyone know of one that might be better or deliver the same sound for cheaper, and can someone also tell me what a hybrid tube amp is?
Wich speakers? Sensitivity and minimum impedance?With high sensitivity, maybe the Musical Paradise.
Signal to Noise Ratio (8 Ohm load):> 120 dB; ref rated power; (A-weighted).> 100 dB; ref 1 watt; (A-weighted).Minimum Recommended Load Impedance (per channel): 4 Ohms(which equals one 4 Ohm load or two paralleled 8 Ohm loads).Gain: 29 dB.
Distance to speaker?If Emotiva, much better idea the A150 $299https://emotiva.com/collections/amps/products/a-150https://www.amazon.com/Emotiva-Audio-stereo-power-amplifier/product-reviews/B06XSCCVV1/ref=cm_cr_arp_d_viewopt_rvwer?ie=UTF8&reviewerType=avp_only_reviews&sortBy=recent&pageNumber=1But you want an integrated and not a poweramp.Ask Danny.
With poweramp you need a preamplifier or DAC with preamplifier. Volume, output select....Do you have a DAC USB?
What is the difference between an integrated and a Poweramp?
I know the answer!But first: which type of music you want to play? Very important question.
