Amadeus 254
0 Members and 1 Guest are viewing this topic. Read 9387 times.
Stevegnz
Amadeus 254
« on: 13 May 2018, 09:25 pm »
Any news on this new WTL turntable? See it retailing for 8500 euros with a GT version for 10500 Euros. Any idea of release date, specs, etc?
Regards Steve
Erocka2000
Re: Amadeus 254
« Reply #1 on: 15 May 2018, 01:09 pm »
Can you post a link to where you've seen this table?  I've never even heard of this model.
Stevegnz
Re: Amadeus 254
« Reply #2 on: 16 May 2018, 12:12 am »
Analog planet (stereophile) Munich 2018 hi fi show day 1 walk around. About 16mins into the video - you'll recognise the kiwi accent. ( do we really sound like that??)
Highlights are it has a split plinth with the squash balls in the between the two layers and has the same RCA or XLR outputs as on the royale. I think he said it had the power supply built in. There will be a GT version with an aluminium top, standard is in bamboo. Uses the Sym/Ltd tonearm (looks standard size).
I understand it will slot in below the royale but above everything else, (a baby Royale?) and that both amadeus tables are to be phased out as the simplex and versalex cover that territory now.
It is a thing of beauty.. I am considering this or the versalex once they have released it. Here in NZ im told we should get the details next week once Frank and Mike are back from Munich
Erocka2000
Re: Amadeus 254
« Reply #3 on: 16 May 2018, 02:05 pm »
It looks interesting.  Though I wish they would change back to a rubber drive belt and make speed changes accessible by a switch or button.
gagamut
Re: Amadeus 254
« Reply #4 on: 17 May 2018, 01:52 am »
The new Amadeus ,It's look like a Baby Royale :D
the motor and arm board is isolate,it's good.
but don't know the motor will be replace the high standard grade?because i found my Amadeus motor not stable sometime ,don't know why
ADiG
sammonte
Re: Amadeus 254
« Reply #6 on: 20 Oct 2018, 04:51 pm »
...noted the comment ...RCA or XLR outputs as on the royale ...
Is this output for "special" carts using one or other when outputting signal? Maybe I don't know advantages of XLRs on phonostage side...
sammonte
Re: Amadeus 254
« Reply #7 on: 21 Oct 2018, 01:35 am »
New, 10/17/2018 article, regarding the serious technical leaps (unfortunately in German) for this gem..
https://www.alpha-audio.nl/2018/10/amadeus-254-platenspeler-van-well-tempered/
sammonte
Re: Amadeus 254
« Reply #8 on: 21 Oct 2018, 01:48 am »
Oops. Above link to the short and sweat web-article is in Dutch Language <has built-in ads> and easily translates via browser <right click>, if not shown in 'default English' translate check-box.
FROM ARTICLE: Denmark also has a hi-fi trade fair: the Copenhagen High End Show . This year, held on 27 and 28 October. More show-news to come...
RPM123
Re: Amadeus 254
« Reply #9 on: 21 Oct 2018, 04:35 pm »
