Pro Sound Powered Subwoofer Compatability with 2 Channel preamp
0 Members and 1 Guest are viewing this topic. Read 1808 times.
man630
I’m currently using a Mirage BPS 150 powered sub with a NAK CA 5 Preamp. Wired with the speaker level  inputs( power amp output to sub and sub to speakers). A local church has a a Yorkville  LS 700p and a LS720p powered Subwoofer they want to sell. Can either of these subwoofers be connected to the Nak ( the CA5 has 2 preouts) with adapters 1/4”  to the Rca on the Nak? Photos of the Yorkville Subwoofers enclosed. The Mirage Subwoofer will be replaced by either Yorkville Subwoofer.
Randy
guest61169
  • Guest
I don't see why not.  Having owned a 720p, however, you might not like having a boost that is adjustable but not defeatable and the sub doesn't produce deep bass.  If you are using it at home, you might be better off getting a consumer sub such as SVS, REL, etc.
Yeah, why not?
Note that professional subs perform better than consumer subs for a given the same set of specifications.
