SOLD: B&C 12TBX100 12" High Power Woofer 8 Ohm - 3 available
0 Members and 1 Guest are viewing this topic. Read 739 times.
TomS
These beefy pro drivers were used in small subwoofers for 2 channel home listening room and are very lightly used, in excellent condition. The factory push terminals no longer function so the driver wires will need to be soldered on, but they are much more secure this way. These are as close to new as you can get, and are typically $257 each from US distributors. These are the same drivers used in the Gedlee Abbey and Multi-sub designs.
Built for high power bass applications where space is limited, B&C's 12TBX100 is a technologically advanced 12" woofer that features 1000 watts RMS power handling, a 1" long, 4" diameter copper voice coil with high thermal capability, and a ventilated magnet assembly that provides low power compression.
Very low distortion and an extended response (due to low inductance) is obtained using a double silicone spider design with dual aluminum demodulation rings in the magnetic path. A proprietary water-proof cone treatment is applied for safe outdoor use and installation in adverse climatic conditions.
Buyer pays shipping and Paypal fee, ~30# each from 33957.
I have 3 available, $SOLD
« Last Edit: 30 May 2018, 01:40 pm by TomS »
